Selection of CD Circuit breaker
Is there any recommendation to select a DC circuit breaker?
In a facility there have been some trips and nobody knows the reasson.
The only clue is that DC circuit breaker only has "instantaneous element" settable between 1600 and 3200 A and operates at almost 1 cycle.
Why DC circui breakers do not have thermal element?
Any answers or clues will be welcome!
RE: Selection of CD Circuit breaker
I've seen DC breakers without thermal settings used in UPS systems but I've also seen many other applications where a thermal trip unit is used.
Rafiq Bulsara
http://www.srengineersct.com
Another possible reason is that the battery protecting the critical installation is itself only protected against catastrophic faults such as a dead short, at which point the load is already lost.
Alan
"The engineer's first problem in any design situation is to discover what the problem really is." Unk.
