Full Penetration 60" pipe Butt Straps
Situation,60" trunk line pipe , there are "butt straps" which are used to connect two 60 " pipes which is connected to the main line. The "butt Straps " and the pipe itself are the same thickness in material. these straps are to be "Full Penetration" welded with a 1/4" backing strip of the same material. The process used is 6010 for root and all the passes thereafter. Although, the specification states , "all field welded double welded Full penetration weld must have , at the root, Dye pen. And once the root passes, the joint may be complete . Once weld is completed the weld is Radiographic tested". I believe, at the minimum, this joint, per code, should be non - destructive tested. This joint was not tested post completion. One month later , when the pipe was all grouted both in and out, the contractor performed a hydo test and a leak was discovered ( pin hole leak) coming from the full penetration welds. Needless to say , this particular "full Penetration" was not tested. In the ASME Section 9 , does it state requirements, which are directed toward all full pens to be non -destructive tested? If so, where would that be located. Thank you
RE: Full Penetration 60" pipe Butt Straps
