Is it acceptable according to AWS D1.1?
Dear Friends
Applicable Code - AWS D.1.1- Sect 4 Part B-Table 4.8.
In Module Skid Fabrication European Steel- S355JR, S275JR,A355JO used( Unlisted Material in AWS D.1.1).
Is it right/appropriate to use WPS/PQR Qualified using EH36 as base material?
If acceptable, pls advise ref. section of the code.
If not accepatable.what is the option? Require requalification?
Pls advise, Thanks.
Pls advise, Thanks.
RE: Is it acceptable according to AWS D1.1?
If not, re-qualification of welds and welder is required.
http://www.FerrellEngineering.com
Steve Jones
http://www.oilandgaspeople.com/cv/11499664
http://www.linkedin.com/pub/8/83b/b04
