PLC/HMI Communication issue
I need help configuring communication parameters for my first PLC/HMI system being developed for a small alarm system project.
I have a Mitsubishi Fx1n 24MR PLC, programmed using GX developer Version 8.0F. No communication parameters have been modified in this application.
The HMI panel is a Biejer E100, programmed using E-Designer 6.13.
The E100 panel connects to the PLC via a CAB19/3M cable. The E100 gets its power through this cable from the PLC.
Both PLC and HMI programs have been loaded successfully to their respective devices.
Problem: When the HMI panel is connected to the PLC and the system powered up, the HMI panel displays '1:Comm Err'.
Any guidance would be greatly appreciated.
Many thanks - Nick
RE: PLC/HMI Communication issue
Hi
Have you checked the comms parameters in each device? baud, parity etc
www.plcprogrammers.co.uk
