Pipe sleeves in concrete
Hi everyone, I have a GRP pipe passing through a concrete chamber, the chamber contains an ultrasonic flow meter. for the interface between the pipe and the concrete wall of the chamber I am proposing that a pipe sleeve is cast in the chamber wall and the pipe is then passed through it. the EPC contractor wants to wrap the GRP pipe with Flexible material and concrete over it, he is saying that this is a standard method of doing things, does any one know of standard details for this type of thing?
RE: Pipe sleeves in concrete
standard for where in the world?
Arguing with an engineer is like wrestling with a pig in mud. After a while you realize that they like it
sorry about that, I am using british standards, but if there is any other details that may be considered " good practice" that will do
At the industrial facility I'm at, I've seen conduits and some pipes such as storm drainage run through walls and floors and just grouted in.  While other piping is run through a couple of sizes larger pipe sleeve and filled in with fire seal material.  It not real familar with the design, but my guess is that it has to do with how much pipe movement your dealing with.
Wrapping cast in pipes with a flexible and compressible material, such as a foam rubber, is a commonly used detail where I am.
Typically, sealing of annular space around piping is based on requirements for preventing water penetration or fire resistance.  For centering/support of pipe and filling the gap a link-seal is commonly inserted then caulked with a sealant.  This type may also be fire rated.  Fire resistant ratings are based (in the U.S.) on tested "assemblies" as qualified by various manufacturers of fire barrier systems such as 3M.
