Linear Pattern and Scale at the same time
Hi All,
I have some cuts that I want to pattern and scale each instance a different factor, sort of a more elaborate area fill. My plan was to create the feature as a solid, pattern it, scale each body, then subtract the whole works. However when you use the linear pattern the feature is created as a single body.
Is there a better way to approach this? Or is there a way to separate the bodies in a pattern.
60% of the time, it works every time.
RE: Linear Pattern and Scale at the same time
1) Create a cut such that both its position and size change when you change 1 dimension. One easy way to do this is to create a circle that is positioned from one edge, but is also tangent to an angled construction line.
2) Start the Linear Pattern command, select the positioning dimension as Direction 1, and enter the desired spacing/instances.
3) Select Vary Sketch and finish the pattern
