Best method of structural vibration damping
Here's the problem. There are two pumps on a concrete floor in a pump house. The floor seems to be supported adequately with pretty substantial steel sections beneath, though they are quite rusted. The superintendent brought us on to fix a problem with vibrations before they put in a replacement for one of the pumps.
My question is what is the best way to go about damping the vibrations? I'm thinking the steel probably needs to be replaced, just because it's really old and parts of the webs are just about rusted through in spots, but that won't solve the vibration problem, I don't think. I've thought of thickening the floor slab to increase the mass, or adding an elastomeric pad beneath the pump pads to isolate them.
Any other ideas? Do these sound like they'd fix it?
RE: Best method of structural vibration damping
Does anyone know if it's any good/worth replacing the floor for?
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
http://www.mason-ind.com/masonind/home/index.cfm
