Bill of Material Format
I need to reformat the appearance of the inserted BOM on the face of my CATIA dwg.
I need to modify not just the cell lengths, but also the font, font size, cell height, justification of text with cell, etc. Does anyone know how I can get started on this?
I found the CATAsmBOM.CATRsc file, but it only deals with cell length.
RE: Bill of Material Format
BOM generation uses current font settings ie. modify font in text properties bar before generating BOM
Regards Timo
Thank you for your response!
Yes, I know of the "font default" action. However, I am looking for a way to permenantly change the BOM's that are generated. If I make a change to any of the children components, the BOM will regenerate back to the original form. I am still looking for a way to change cell hieght and lock in these characxteristic. Is there a way to disconnect (or isolate) BOM tabled?
Ken
I've got a problem with BOM, but not in CATIA dwg.
I want to know if there is a way to put the catalog's attributes in a BOM.
Can I just use the attributes I have in properties box?
Can I visualize the catalog's attributes in a BOM?
Thanks!
Regards.
Everton.
