fluid compressibility - spring effect
Dear All,
I have found a brief statement that the spring effect of compressed fluid in hydraulic devices depends on the jerk (first derivative of acceleration) of the piston movement.
I can clearly see from an experiment that this is true but I would like to know the detailed explanation. My first thought would be that it depends on piston velocity but obviously I am wrong.
Many thanks in advance!
Nado
Nado
RE: fluid compressibility - spring effect
"The problem isn't finding the solution, its trying to get to the real question." BigInch
http://virtualpipeline.spaces.live.com/
Thank you! So it was good old Mr Newton again
