Copying an asmbly without the previous cosmos results
Hello Guys,
when saving an sambly under a different name(save as copy), SW also copies the previous cosmos results with it.
I only want the asmbly not the previous results, so no data under the simulation tab.
It's getting old to recreate the assembly again and again..
p.s. deleting the results in the new asmbly deletes the original results(same working directory).
Thx in advance for your help!
RE: Copying an asmbly without the previous cosmos results
I had that thought too so I tried it this morning. I think it's misleading for as far as I can see, the Cosmos data for the parts is still there. What doesn't get copied over with Pack and Go is the reports. I guess that is printed type reports not the analysis data itself. Having said that, someone else may call me wrong.
Interesting observation. I'll have to investigate (not before Monday).
Thanks to all!
