Belt drives
Belt drives
I am looking at an application where, I am employing a belt drive system into a speed reducer.
Specification:
** Output speed = 500rpm
** Output Torque = 1.5 lb-ft (2Nm)
** Ratio = ~9:1
Also noise is an big issue. Having never specified a bel-drive system before, please can anyone advise me of the following.
1) What belt profile gives the best noise isolating properties?? (Standard type only, flat, Vee, timing etc.)
2) Where I can find calcuations (via a website or spreadsheet) on how to calculate the what pulley sizes, pitches and widths.
3) Does the belt material make a difference to the noise characteristics.
Thanks for your help,
Russell Tannner....
Specification:
** Ratio = ~9:1
Russell Tannner....
RE: Belt drives
Sorry for all the questions, but pulley ratios are real easy once the system and space limitations are stated.
Gates Belt catalog does a good job of describing belt selection, and the end use is also very necessary to determine what type (Vee, timing, etc.). Shock loads, safety concerns, etc. play a role as well.
Roach
RE: Belt drives
The motor is supplied by our customer and I'm not sure what it is, but the input speed is 4500 RPM.
The belt drive unit needs to be 9:1 ratio. The motor is attached directly to the unit. ie. the motor shaft has the input pulley mounted to it.
Russell..
RE: Belt drives
Roach
RE: Belt drives
Keep the wheels on the ground
Bob
showshine@aol.com
