Rerating of shell-and-tube heat exchanger
Could a shell-and-tube heat exchanger be consider as a pressure vessel?
What do API or ASME selections contains methodologies of rerating of a  shell-and-tube heat exchanger?
RE: Rerating of shell-and-tube heat exchanger
Yes. Depends on the MAWP stamped on the shell nameplate.
The NBIC is one source for boiler/pressure vessel reratings. The second is API 510.
