Pum drains
Pum drains
Pum drains
We have this pumps installed acording to API, but I am afraid the drains shown in the picture attached will break with the pumps vibration, any suggestions?
RE: Pum drains
"I am afraid the drains shown in the picture attached will break with the pumps vibration, any suggestions? "
Yes!  Find out why the pump is vibrating and fix it.
RE: Pum drains
The pump is has not been started yet, we are finishing the project, I believe there will be some vibration...Thank you
RE: Pum drains
You need to have an "open drain"! This is where you place a drain hub (usually a reducer large end up) where it sticks above grade about 3" to 6". Then you direct your drain connections to be positioned about 2" to 3" above the "hub". So all you have to do is crack the valves at these locations, the discharge is then directed into the hub and then down in the drain header.
