Adhesive/Cementitious Grout
The following is from an eMail sent to a grout supplier...
Can anyone suggest a product?
We have a project as follows. Existing concrete is sound and good quality and is approximately 40 years old. This will be cored with a 6" dia core drill for a length of approximately 20' to 25'.
We need to anchor a high strength 1-3/4" dia Dywidag threadbar into the bottom of the hole using a cementitious grout. Temperature of the concrete will be approximately 0 degC to -5 degC.
The threadbar will be tensioned to a service load of approximately 320,000 lbs. The grout will have to bond to the freshly cut concrete surface and will have to develop suitable strength within two days. Service loading will be sustained over several decades (>50 years). Quality control and quality assurance will be first rate. The anchorage development length can be several feet.
We are currently entertaining the use of Sikadur VPC. Is this product suitable? Is there a better product that you can recommend?
thanks, Dik
thanks, Dik
RE: Adhesive/Cementitious Grout
Dik
Dik
http://w
BA
Dik
