Heat and pressure derating for evaporator.
I have a Kontro Thin Film onsite that currently uses 150 lb steam (hastalloy c inner wall with carbon steel shell). Customer wants to use hot oil. The tag says 150 psi at 400F. How do I de-rate the pressure of the unit for operation at 700F?
