Modeling a Tube Frame in UG/NX.7
thread561-106807: Best approach to modeling a tube-frame chassis Hello,
I am part of an FSAE team and we are trying to model our tube frame in UG/NX 7. So far we have been able to figure out how to make the wire frame model of the entire frame using sketches on various planes and using the spline function and have used the tube function to place tubes along all of these lines. Now the problem we are encountering is fixing all the joints of the frame. I know that in Solid Works it is a simple function of just trimming and extending the tubes to get them to join how you would like. In NX this does not seam possible.  Could anyone shed some light on how to make these joints work? Most of them are not a fish mouth type joint, they are angled joints so that the tube section is continuous.
Also, is there a way to have the tube function go around a radius or bend?
Thanks in advance
RE: Modeling a Tube Frame in UG/NX.7
You can always Trim the end of one tube with the face of a mating tube, as I did with the simple attached example file.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Hello, I am also having troubles trimming the tubes to mate with joining tubes.  I am working on a SAE Mini Baja car and would appreciate any advice you can give.  I have attached a file from NX6 of the front suspension support.  I tried to follow the link above but I couldn't open the newer file on my schools NX6.  Thanks in advance!
