Adding components to assembly in Pro-E
Putting together an assembly that has a cover plate requiring many washers and bolts. Was curious if anyone knew a way to add these components in a quicker fashion rather than one component and two constraints at a time?
RE: Adding components to assembly in Pro-E
If the holes are a pattern, then insert one set to the pattern and let the pattern fill them all in.
If the holes are random, then it is one-by-one.
Ben Loosli
