How to update custom view in drawing?
When I hide a component in a (custom)view in the modeling environment, it doesn't update the view in the drawing. Why??
I use NX6.
Michel
I use NX6.
Michel
I use NX6.
Groeten, Michel
www.kvi.nl A leading Dutch institute in atomic and subatomic physics
RE: How to update custom view in drawing?
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
If you want to hide a component in the drawing view you can either makes its layer invisible in "visible in view" or hide the component using:
assemblies (pull-down) > context control > hide component > follow instructions in your "cue/status position" window
I am in NX6
If you put together the two explanations given by John and later Jerry the thing to do is to simply hide the component in the drawing view instead.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
So making a view for the drawing is just a 1 time action, that's a pity. Why didn't they make it associative?
And is there any real difference between using a view from the master model (with asterix) or from the dwg.prt to put in your drawing? I know an exploded view only works in the dwg.prt.
I use NX6.
Groeten, Michel
Best Regards
Hudson
www.jamb.com.au
Off course i know that views in the drawing update if a part changes.
What I mean is that when I hide a component in view in "Modeling" it doesn't hide this component in the same view on the drawing if this view already existed.
btw. I did modeling 1 & 2, adv. asm and adv. sim.
I use NX6.
Groeten, Michel
Best Regards
Hudson
www.jamb.com.au
