Meaning of TST on Boiler Datasheets
Is anyone familiar with the acronym TST as used on boiler datasheets? Can you tell me what it means?
I believe it is related to superheater outlet temperature, but the documentation I have also uses the term superheater outlet temperature.
Thanks.
RE: Meaning of TST on Boiler Datasheets
Would it be possible to copy off a bit of the datasheet so that we can see it.  The same TLA* can mean different things to different people, depending on the industry.
Without any other information, I'd normally interpret "TST" as "test", but that doesn't seem to fit with what you were thinking.
*TLA: three letter acromyn
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
Is is a P-3 or P-4 form (Mfr's Data Report form)?  What Line of the form does it appear on?  I've signed both P-3 and P-4 (and P-4A) data report forms and have not seen TST acronym used.  Is there a Tubesheet on the boiler or Part?
Tube Side Temperature?
