Stainless for HCl Containment
What is the best stainless steel to use for containing small amounts of Hydrochloric Acid; this is part of a filling process and any drips should be cleaned up in a short period of time (assuming the driver does this). The HCl is roughly a 35% solution.
Dik
Dik
RE: Stainless for HCl Containment
Dik
have a look at this publication from NIDI:
http://
S
Corrosion & Rust Prevention Control
Whenever you can choose corrosion immunity over corrosion resistance, you should. Homopolymers, FRP and coated steel are all possibilities.
