flat pattern visible in assembly
I'm not really familar with Nx6 sheet metall.
We have sheet metall part with some flanges with FLAT PATTERN FEATURE. The curves are transfered into a view and a spe. layer. Working with entire part referenceSet in the assy of the sheet metall part the flat curves were shown. Reference set model fixes the problem. Are there any other opportunities to control the visability of those curves in the assembly or if you add this sheetmetall part master model to a drawing with entire part?
thx in ad
thx in ad
RE: flat pattern visible in assembly
Now in the case of a Drawing of the actual sheet metal part itself, with the Solid in the Model Reference Set, create your Master Model Drawing and place the views of the as formed sheet metal model and then to include the Flat Pattern, place another 'Base View' only change the designated named view to the one which was created when the Flat Pattern was defined and place that on the Drawing, so that now you have both the as-formed and the flattened version of the model on your drawing.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
thx ( esp. John Baker)
Also, from what you've stated, it seems to suggest that you be ONLY allowing the use of Reference Sets inside of an Assembly. Is this true? If so, that is the exact OPPOSITE of what Reference Sets were designed to be used for. We do NOT recommend that you ever create Reference Sets in an Assembly. They act as explicit filters and could eventually cause you all sorts of problems which may prove be very difficult to sort out months from now when they start to manifest themselves when and if these Assemblies are modified and updated, particularly if they contain sub-assemblies or these assemblies are themselves used as sub-assemblies.
'Visible in View', while still supported, is considered an arcane function and should only be used IF there are NO other solutions which meet your needs.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Reference Set are used - in assembly part we use only entire part no reference Set in assembly level. On the components model referenc Set - on drawing we use the component visible in view as first choise layer visible in view and only as last the view dependent options.
layer visible in view ( only in drawing views)is still heavy in use...
Now if they switched off the ability to make new instances of view dependant geometry, or to set up visible in view from within the modelling application then I should not be in a least bit disappointed.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
John R. Baker, P.E.
Industry Sector
Cypress, CA
Both folded and flat pattern are to be on the same sheet, the only way i can see i'll get it to work is creare a new ref set with both folded and flat in it (on different layers) and use visible in view, i'm trying to avoid this method from recent thread explanations, but can't see another way?
With NX 6.0.5.3, when I create the Master Model Drawing and I add the Component for the 'a- modeled' views, the system automatically used the 'Model' Reference Set. However, when I then add another 'Base View', only this time I selecedt the view which was defined automatically when the Flat Pattern was created, a second Component was automatically added to the Master Model Drawing only this time it used the 'Entire Part' Reference Set and everything came out exactly as I wanted it to, and I didn't have to change any setting or switch Reference Sets. If you just let the system do what it wants, you will generally get what you need to do the job correctly.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Make sure you follow John's earlier instructions absolutely to the letter, and don't confuse "flat pattern" with "flat solid".
Best Regards
Hudson
www.jamb.com.au
John says "with the Solid in the Model Reference Set",
Does he mean i should add the flat solid to the model ref set?
Also he says, change the " view to the one which was created when the Flat Pattern was defined ",
Does he mean a view should automatically be created when i create the flat solid?
I'm having trouble understanding the purpose of the system created "flat solid" ref set...
The drwg can only see one ref set, therefore it can only draw, the formed OR flattened part??
Unless i add the both features to a new ref set,
John seems to be explaining how this can be done from the std model ref set How??
BOP, comprendez, i was just trying to avoid these extra steps, but it's actually not that bad eh?
