Corrosion of Aluminum part inside Liquid Sulfur Tank?
I am designing a component that will be submersed in liquid sulfur inside of a storage tank.  The component will remain submersed for years at a time.  It will also, at times, be exposed to the air space above the liquid level which will contain H2S.  I would like to make this part from Aluminum.  What sort of corrosion should I expect while submersed?  While exposed to the airspace?
