advice Needed - Joints in a Concrete Seawall
I'm reviewing the final plans for the replacement of a bulkhead. Here are the particulars:
Existing gravity wall of unknown dimensions. The top 4-feet will be completely demolished. On the remaining portion an 11" layer of concrete will be removed from the front face of the wall, down to about 3' below the mudline.
A pseudo-soldier pile and lagging wall will then beconstructed. I use pseudo because the lagging will be cast in place concrete. See attached plan view. Total height of new wall is about 11'. MHW is 4' below top of wall. MLW is actually below the mudline.
Soldier piles (W18x234 at 7'-6") will be installed in 30" diameter holes drilled through the wall, and then socketed into rock. The piles are about 30' long.
The "lagging" will be cast against the old wall and also encase the soldier piles. 11" minimum thickness of concrete, which is a marine grade concrete - low shrinkage, self-consolodating. The rebar is stainless steel.
The plans call for expansion joints at 120'. They use a standard retaining wall detail with waterstop and joint filler. The designer also calls for dummy joints every 30'- that's giving me grief! My gut feeling is that cracks will form at each soldier pile. In front of each pile the wall is only be 5 1/2".
Any thoughts would be appreciated.
RE: advice Needed - Joints in a Concrete Seawall
DaveAtkins
Michael.
Timing has a lot to do with the outcome of a rain dance.
The horizontal rebar does exceed .5%
The expansion joints do seem useless. The wall is going to be cast against the existing wall
