bolted lap joints formula and example calc
i need to design a lifting point on a column, i am looking for bolted single shear lap joint calculations (metric)
RE: bolted lap joints formula and example calc
Have a look at this site, also there are links to other sites:-
ht
desertfox
Hi des007
Here's another example:-
http
desertfox
example 11 in this pdf does a bolted lap joint in double shear as opposed to your single shear but it might help:-
http://a
regards
Des
NASA RP1228
AISC 360
Eurocode 3, Part 1.8
Does 8mt on your drawing mean 8 (metric) tonnes?
I think I can do this analysis, but if my boss brought this to me, I would advise him to take it a structural engineer. It is not just the lap joint that can fail.
I would have to agree with drawoh, the requirements for lifting lugs are pretty tight and 8mt isn't some trivial weight. Judging by the pinhole size alone in relation to the rest of the lug this is probably not a great design.
