Fonts in NX5 and above
Is there a ug font that contains the circle r, or that will accept alt+0174 and other alt combinations?
RE: Fonts in NX5 and above
$z will show as the reg trademark symbol.
It may or may not work in the font that you are using - change the font of the "$z" to "blockfont" if it is not showing up correctly
a tip: do a search in Help > Documentation > enter "symbols and text control characters"
and what you get should help you
John,
Thanks for posting the crib sheet.
As an added note to the crib sheet.
The crib sheet is ONLY valid with Blockfont as supplied by Siemens.
John has posted a modifed Blockfont file that has additional characters that are not on the crib sheet.
Ben Loosli
Thanks for the info, John.  I also found that the font iso1 has some alt+XXXX combinations that work as well.
nmilitner,
Can you tell us about the alt+XXXX combinations ?
Is that ascii based?
One more question on symbols and fonts.  This time it pertains to attributes.  If i put, for instance the $r in my attributes, for a diameter symbol, that are used in title blocks I actually get $r in the text line that is on my print.  Any way around this?
To be more clear:  attribute Gauge=$r .125
                  expected text line Ø .125
                  actual text line: $r .125
I never realized that those "$" fonts cannot be used as the attributes that appear in the title block (or anyplace else). That is very interesting.
I am going to play around a bit to try to make it work, but I would love to hear if John Baker has a solution.
nmiltner, try this ;
attriute Gauge=<O> .125
that's a capital o (not zero).
Hope it helps.
Best regards,
Michäël.
NX4.0.4.2 MP10 / TCE 9.1.3.8_build_0711 / NX6.0.2.8 / NX7.0.0.9
Belgium
Mickey,
I tried the <O> as well.  That too isn't working.
Jerry,
Yes, they are ascii combinations.  For instance, if your font is iso1, and you type alt+0176 you get ° (the degree symbol).  You can find the alt combinations in windows character map.  NOTE: not all characters are supported.
Now that is weird ... one time I tried <O> it worked, and the next time it didn't
Thanks for the ascii tip ... that is good stuff
It appears to me that <O> will work when it shows up in a parts list, or table, but not as stand-alone text
An Attribute, when referenced by a note, is interpreted as a literal string.  That is, the exact characters are inserted into the note exactly as they appear in the Attribute.  They are NOT 'evaluated' as they are when you type them in directly.  I suspect that if we DID 'evaluate' them, so that the control characters WERE interpreted AS control characters rather then just as a text string, that this could cause all sorts of problems since there would be no way of determining what the user was expecting.  That is, which Attributes are to be treated exactly as they appear, and which ones would need to be 'evaluated'.  At least when entering text directing into NX you can always override the control characters by typing in a double '$$'.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Turns that there is a way of working around this, but you have to manually edit the text string which is used to reference the Attribute.
When you create the link to the attribute the string that is shown in the test editor will look something like...
<W@ATTRIBUTE_NAME>
...and the result will be non-evaluated.  However if you were to edit it so that it was...
<W&@ATTRIBUTE_NAME>
...then it would be evaluated (the edit involved adding the '&').  I had forgotten about that until someone just reminded me of it.
John R. Baker, P.E.
Industry Sector
Cypress, CA
John,
YOU ARE THE MAN!  You never cease to amaze us with your knowledge.  Thanks for this one.  Our users will be very greatful.
