Laser marking of ZrN
Hi, I am looking for ideas on how to laser mark tool steel coated in ZrN without breaking the ZrN layer exposing the Tool steel. (Due to the part being used in a wet environment it will rust). Any ideas would be great.
Richie
Richie
RE: Laser marking of ZrN
Chris Krug http://krugtech.com/
That would be great if you could find out what that material was. I look forward to your reply.
Richie
"Laserbits, 1734 West Williams Drive Suite 10, Phoenix AZ 85027
1.800.733.7705
Product is called CerMark metal marking solution, it now comes in a spray or paste."
In return, I only ask that you let us all know how it works out for you.
Chris
I ordered the spray and it worked well enough, the thing was it was hard to control the amount sprayed on. too little and it burned through, too much and it didn't mark it at all. Thanks for all the help though.
Richie
Richie
