Different Grade of Stress Analysis
Recently I recieve a detail of work for a bid; but I can not understand this:
STRESS ANALYSIS FOR GRADE "SC"
STRESS ANALYSIS FOR GRADE "C"
STRESS ANALYSIS GRADE "M"
STRESS ANALYSIS GRADE "I"
Somebody here knows about that? and what include this kind of Stress Analysis?
Luis F. Cadena
Luis F. Cadena
RE: Different Grade of Stress Analysis
Thanks for your help. This project is about broadening a refinery, replacement of old equipment, implement new systems, connect new equipment through tie-in points. Do you need more information? let me know as soon as possible; again thanks for your help.
Luis F. Cadena
(right now, more information is probably better, and specific information is better than general information - the more you make this like pulling teeth, the less likely you are to get someone interested enough in your problem to provide you with an answer...)
Thnaks
"The problem isn't finding the solution, its trying to get to the real question." BigInch
http://virtualpipeline.spaces.live.com/
Luis F.
Why don't you just ask the individual/company that gave you the requirement - it could be specific to a project. These terms are not specific to ASME B31.3.
I - Inspection
M - Manual Calculation
C - Computer Analysis
SC - Dunno, maybe Computer Analysis + Supplemental (i.e. NEMA SM-23, API-610, other FEA invlolved)
Edward L. Klein
Pipe Stress Engineer
Houston, Texas
"All the world is a Spring"
All opinions expressed here are my own and not my company's.
Start on page 40. No definitive answer but there maybe some leads.
http
