SolidWorks Electrical Routing Through Solid Bodies
I am using electrical routing in SolidWorks 2010, and do not know how to get the routing program to recognize it needs to route around, and not through, solid bodies.
The body I am trying to route around was translated from a .CATpart to .step file and then imported (not sure if this is the problem).
Any tips would be greatly appreciated.
Nicole
RE: SolidWorks Electrical Routing Through Solid Bodies
You just have to play with your 3D sketches to get the route right.  There is no way (as far as I know) to tell SW to avoid contact with solids bodies.
Dan
www.eltronresearch.com
Dan's Blog
