Small Scale Turbine Compression Question
Hi there,
I'm working on some concepts for a clean solar energy collection and storage facility (enough to power a 3rd world village daily). A particular idea of interest is that of compressed air (150-200bar).
How viable would turbine compression be for this application? What sort of efficiency could I expect from the compression stage, and what sort of effciency could I expect using the compressed air to drive a fan/turbine at a later stage?
Help is greatly appreciated! Thanks.
RE: Small Scale Turbine Compression Question
As for your specific question, assuming scale factors are towards the smaller side, you should expect to have overall efficiencies of no more than 15% from compressor input power to power delivered to moving air by the fan.
At 100 psig, specific power is approximately 16 kW/100 cfm to 18 kW/100 cfm.
"The problem isn't finding the solution, its trying to get to the real question." BigInch
http://virtualpipeline.spaces.live.com/
Why not look at doing it with water? Use the solar to pump the water into a water tower, then run a water wheel powered generator. If the water tower springs a leak, stopping the leak can be pretty low tech (a stick and a rubber patch). Buying a tank that you can put in an elevated location (either on a hill, on a pedestal, or on a support structure) is a lot less expensive than getting pressure vessel rated for 150-200 bar. I don't have the efficiency numbers on a pump/water wheel/generator lash up but my bet is that it is better than you'd get with a compressor and gas turbine.
David Simpson, PE
MuleShoe Engineering
www.muleshoe-eng.com
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
"It is always a poor idea to ask your Bridge Club for medical advice or a collection of geek engineers for legal advice"
Then you've still got to account for motor and fan efficiency to get to actual power delivered to move the air. If that's 0.9 x 0.6, you'd be back to 12% overall (100 psig pressure system) again.
Working with high pressure air, it probably wouldn't be much more than 6% with a throw-together system ... and dangerous. I imagine that you'd probably wind up just using the air to fill tires really fast ... for awhile.
