This run of I-DEAS has ABNORMALLY ended. (Segmentation Violation)
We have not used I-DEAS for some time now. I need to access some legacy data and cannot start ideas on the old computer.
I receive this error in the command window
"This run of I-DEAS has ABNORMALLY ended. (Segmentation Violation)" as well a Program Error window that states "ideast.exe has generated errors and will be closed by Windoze. You will need to restart the program. Nothing on the computer has changed. Its still a windows2000 os. Any help would be appreciated.
Mark
Mark
RE: This run of I-DEAS has ABNORMALLY ended. (Segmentation Violation)
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
(You can find the location of your team directory by opening an I-deas command prompt and typing dmadmin followed by stat_idm).
A new param file will be created the next time you login and will give you a blank entry in the model file view startup. If this fails have a look for any error.out files in your I-deas startup directory which may give some clues.
