polar drilling
polar drilling
polar drilling
Hi
Im using NX6 my problem is that I need to output drilling paths as POLAR moves, is there any way of doing that from within NX
Many thanks
RE: polar drilling
You have to program your drilling operations as normal and under Objects=> Start Events select the Set Polar UDE and set to on. You may have to make changes in your post depending on you machine/controller.
RE: polar drilling
Thanks John
Ive tried using the poalr UDE prior to my post but unfortunatly the post doesnt handle it. I was hoping for  an alternative but will have to get onto our postbuilder (externally sourced)
