Reposition components move handle only
In NX2, there is a button on moving/repositioning a component so that the orientation of the handle matches the WCS.
Is there such a thing in NX5? In the specify orientation, there are two icons to the right, one is point dialog and the other says position. I keep on clicking the position icon and the handles does not orient along WCS. I got move handles only checked.
UGNX5.0.4.1 MP6 \ WinXP-SP3
Productive Design Services
www.productivedesign.com
RE: Reposition components move handle only
If you go to preferences, assemblies, assembly positioning interaction, select "mating conditions" instead of "positioning constraints"
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
in NX4 are you dynamicly repostion a component the was an icon that let you change the dymanic part wcs back to the working WCS....
Also another question is when I add a view to my drawing there is no way to change the visible in view till after you place the view? is this right?
also when placeing a point for example in the coordinate window there is no way to reset the x, y, z, back to all zero's (nx4 had a reset button)
sorry for all the questions but I am the fist here to start using NX6 and I have to teach the rest next week and I just got it this week... SOP
Cj Silver
from the shadows, looking for enlightenment
Also another question is when I add a view to my drawing there is no way to change the visible in view till after you place the view? is this right? No you can edit the visability - select the view border and right click and pick Style.
To reset the point dialog click the reset button. On the top of the dialog the small backward curly arrow thingee.
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
