two significant numbers in colums
Is there a quick way to change many numbers after decimal points to two significant numbers within a column?
RE: two significant numbers in colums
Or are you looking for a set number of significant digits? If so, there are some old threads on this subject:
thread770-39236: Significant Digits is one
TTFN
Add a column, use TRUNC to create the truncated number and then Copy and Paste Special to get the truncated number into the original column. Delete the added column.
Stephen Argles
Land & Marine
www.landandmarine.com
But usually (if you want to change the actual number, rather than how it is displayed) you will want to round, rather than truncate, so use = ROUND(Cell,2)
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
=round(cell,INT(# Significant digits - log(cell))
this formula will work for both normal numbers and decimals
