Simulating a Weld
Simulating a Weld
I have two aluminum plates that are the same dimensions which are laid directly on top of each other. I am trying to figure out a way to simulate a weld around the edges of the plates. I need to take the nodes located on the edges that are in connect between the plates and tie them together. I have looked into using point-based fasteners but it seems they only simulate spot welds not continuous welds. I think connectors might be able to connect the faces the way I want but I do not know how to make that happen. Just looking for some insights.
RE: Simulating a Weld
Rob Stupplebeen
