Cantilevered steel column design
I have a question regarding cantilevered steel columns as the seismic force resisting system. I have a steel framed platform on the interior of a building. I am using cantilevered column system G.3 from Table 12.2-1 in ASCE-05 with R=1.25 for the platform. Also, section 12.2.5.2 limits the axial load on the cantilevered column elements to 15% of the column capacity. My question is, when calculating the axial capacity of the columns, should I be using K=2.1 for a cantilevered condition, or can I use K=1? The columns are obviously cantilevered under horizontal loads, but for axial loads are they braced by the platform floor framing (i.e. essentially by the other columns, i guess). If you combine the 15% limit on axial loads and K=2.1 the columns get really conservative in my opinion.
RE: Cantilevered steel column design
cantilevered columns? is this a free standing structure with the moment resistance provided by the platform framing?
Dik
Dik
BA
