feature based machining help
Hi Guys,
I want to export, some customized drill strategies done on NX
to my Machining Knowledge editor.
How can I export the information between NXCAM to MK editor?
for customized drills.
Thanks.
Thanks.
RE: feature based machining help
I'm not an expert on MKE but if you dont want to make a new template for your new drilling strategies you have to write a new rule for it. To transfer the knowledge into MKE I'm working the way "generate the operation interactive and when I like the result I look at the the parameters eg.(Tool.xxx, Oper.xxx) set dem in the rule". Be aware that all functionality which enable interactive is not enable in MKE.....
Keros
Thanks for your answer, I don't understand how can I send the drill operations into a rule.
Know I am customizing some drill templates, but if it's possible I want this templates inside MKeditor. The thing is I don't know how to send them to MK editor code.
I want to use FBM with drill operations, previous drill templates migrated to MKeditor.
Thanks.
