Easy viton adhesive question
What kind of adhesive do I use to glue a viton Fluoroelastomer seal to stainless steel?
We're making a thermal chamber door and we cannot use any silicone so RTV is out.  Temperatures range from -80F to +250F.  Air pressure is room pressure.
This is the seal we're using; http://www.mcmaster.com/#2072t12/=6ceudv
Ideally, I'd like to use an off the shelf adhesive from mcmaster or grainger etc.  I need to order it in fast.
RE: Easy viton adhesive question
I guess it's not as easy as I thought!  Makes me feel better.
Do you have the luxury of trying a shot in the dark? O-ring cord is often joined with an industrial-strength super glue.
Superglue did enter my mind but I didn't know if it would outgas (which is bad in this industry) and I didn't know how long it would last.
At any rate, we ended up rivoting the seal to the oven door.
