Entering parameter values across multiple parts
I need to enter parameter values into about 250 sub-assemblies and parts. Is there a simpler way than opening the top level assembly and using the parameter tool to select each part individually to enter the value? I'm using Pro/E WF 3.0.
Bryan
Bryan
RE: Entering parameter values across multiple parts
If the part/assembly doesn't have the parameter in it, by clicking on the parameter in the model tree, you will be prompted to create it.
