Hastelloy C-2000 Pipe
Are Hastelloy C-2000 pipes available in sizes greater than NPS 8"?  My Haynes catalog only shows up to 8".  Any suggestions for suppliers?
RE: Hastelloy C-2000 Pipe
If you don't find the required size I would give Mach a call about making  it. We've had several different pipe sections made due to availability or a time line problem.  Mach was good to work with.
http://www.machindustrialgroup.com/pipeTubing.php
Dunno if it has changed in the last few years, but the only place we were able to obtain ANY C-2000 the last time we used it (about 7 years ago) was directly from Haynes.  That was NOT FUN...
Are you looking for a piece, a length, or a mill-run?
Thanks for the replies guys.
moltenmetal,
A couple of lengths ranging from NPS 3" to 12".
Well, if Haynes can't supply a certain pipe size, it would then have to be fabricated from plate.
...plate which you would also need to buy from Haynes...
If Haynes doesn't have it on hand as pipe, you're talking about at least 12+ weeks.
Not a widely used alloy- nobody stocks it except Haynes to my knowledge- and they didn't stock MUCH...
If you want to take a mill run of a particular size, you're waiting anyway and the choice of material is less of a concern.
Have you considered C-276 as a substitute ?
Due to the market in Wet Flue gas Desulfurization in power plant retrofits.....there is probably much more C-276 available.
MJCronin,
Hastelloy C-2000 had been substituted with Alloy 59 (UNS N06059) by our metallurgist.
