lifting structral after ASME B30.20 and ASME BTH-1
Hi
I need a little help with a this.
I have to calculate a "simple sheet lifter" please se the attached file. The calculations have to be made after ASME B30.20 and ASME BTH-1-2008. I want to make the global calculations in Staad.pro and here I can make a global code check. My question is can I use some of the codes that are in staad to the global code check. The code are in staad.pro are:
AISC 360-05
AISC ASD
AISC CASTLLATED
AISC LRFD
AISC N690
Can I use one of these for global code check and still meet the ASME B30.20
Thank you for help
