P91 Pre-Heat and PWHT Time Interval
Sirs;
During our inspection, the owner representative questions us: What is the interval time between your Pre-heating and PWHT.
Pre-heating is carried out during welding, afterward the PWHT will be done.
And, what closest ASME code could be supported for this article.
Thank so much
Thank so much
RE: P91 Pre-Heat and PWHT Time Interval
P91 final properties are very dependant upon the correct Pre-heat and PWHT conditions. Do a search on P91 as there are numerous threads on this subject with good contributions from posters such as Davefitz, Meteng, etc. All your questions should be answered by a simple search in these forums.
http
I don't know whether this is the place to mention the Tip Tig welding process but here goes anyway. I have some preliminary information about some outstanding results welding P91. Unfortunately my source had a heart attack and now has a defibrillator and can't get near a welding shop, another excellant welder taken out of the loop.
This wouldn't be anything to run our a grab and expect the goose to lay a golden egg, but, If you have a large project upcoming I think it would be worthwhile to investigate the process.
Here are two approaches to get some preliminary information on the process, both have essentially the same information.
http://tiptig.com/
http://www.weldreality.com/TIP-TIG-Welding.htm
