Moving a fixed component for a drawing
I've got a large assembly with several sub assemblies and I want to generate some drawings with some components moved. I can create an exploded view for the linear moves but I want to rotate some elements (showing some doors opened). The doors are fulled mated but even if they were free they are in a sub assembly so I couldn't move them easily. Any ideas.? SW2009 SP5
RE: Moving a fixed component for a drawing
Have you tried making the subs Flexible?  See the Help files.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
If you need this only for drawings, also check the Help files for Alternate Position View.
totally doable with configurations.
SW2010 Premium SP0.0
Intel Core 2 Duo CPU
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
