filling in the title block atuomaticly
I know its been asked 1000 times but I want to create a seed file that will come in with my imported paper file and then fill in the title block.
I need to fill in the following:
tool dwg number
tool description
engine no.
process no.
customer
tool owner
I am assuming I need to create a gui interface but not sure how?
tool dwg number
tool description
engine no.
process no.
customer
tool owner
RE: filling in the title block atuomaticly
\NXx\UGOPEN\SampleNXOpenApplications\.NET\TitleBlock
we used "E" size dwg
Cj Silver
Unigraphic Designer
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
What is the filename that you use to retrieve the file? Is it the same number that is used for the 'tool dwg number'?
Ben Loosli
Long time no hear as I have been out touch! we are stuck on version NX4
I can put attributes into the file but do not I need an gui interface
have not used attributes in a file since version 9 so need total refresher couse
Cj Silver
Unigraphic Designer
John R. Baker, P.E.
Industry Sector
Cypress, CA
Ben Loosli
Cj Silver
Unigraphic Designer
but how do I added all the other attributes other than file name.
Cj Silver
Unigraphic Designer
In the Displayed Part Properties window, select the Attributes tab. At the bottom are 2 text entry windows, one labeled Title, the other Value. Just enter your title and its value and then Apply. You have an attribute in your file.
Ben Loosli
I knew john when he was just a kid so that should tell you
Cj Silver
Unigraphic Designer
As for your admin's paranoia, please explain to him that we would never have called it 'User Documentation' if we had not intended for the user to be accessing it.
John R. Baker, P.E.
Industry Sector
Cypress, CA
think I have it now thanks for the help
crossed paths along time ago.
Cj Silver
Unigraphic Designer
John R. Baker, P.E.
Industry Sector
Cypress, CA
