Amine problems at a compression station in Texas
I work at a 40 MMSCF compreesor station in Texas. We run 2 MDEA trains and a TEG regenerator. My big problem is my amine still that swings both pressure and level and it is a handful adjusting REDA flows and accumulator pressures. I'm looking for a pro with a few minutes.
RE: Amine problems at a compression station in Texas
2. How the Regenerator bottom level behaves (erratic)?
3. How the heat input is controlled? Fired heater reboiler? If such, how the individual flow passes are controlled?
4. Try increasing the regenerator overhead pressure if nothing else works, and let us know if anything changes.
There is very little data given from your side so we can't be of much assistance. Is Amine still = Regenerator?
http://antwrp.gsfc.nasa.gov/apod/astropix.html
1)Level Indicator on Reflux Accumulator sporadically giving a false 100% level which automatically opened the valve 100% and drained the Accumulator quickly. This has not been fixed and I'm forced to keep a close eye on it and tap it with a wrench to reset it when it malfuctions.
2)Hot Makeup Oil Heater had to be adjusted. The swing on the cycle was such as it would keep going down with any moderate change in Amine flow thru the Reboiler.
3)Change in the Reboiler happened often due to Lo-Lo Pressure in the Still (Stipper). This would take out my Booster and Solution Pumps.
The plant is running well this hitch save for the fact that I cannot run my Amine flow over about 130 GPM or my REDA pulls my Boosters down. All screens have been cleaned, I've run my accumulator at a higher pressure, and changed the P50 sock filter any time I saw it impeding flow from the Flash Tank to the still. I pull hydrocarbons from the Weir in the Flash 3 or 4 times a day and the top of the Carbon Filter every hour.
Foam has been an issue and I wonder if it might be what causes my Boosters to cavitate so often. The good news is that we are treating 26 MMSCF of gas with a 11-13% CO2 down to about 2.5%.
Ypu are advising to check the contamination of lean and rich amines in the lab. What all are the parametrs that we have to analyse in the lab
Mr.Operatorjames
You are experiencing the foaming problem in both amine absortion trains simultaniously or not
