Compress Build 6310 Heat Exchanger Model
I recently modeled a vertical exchanger that is mounted on top of a column vessel. It has a top and bottom tube sheet but only a top bonet. The bottom mounts on a body flange of the vessel below.
I found no way to save my work during the interview process once you enter the HE model. I lost some amount of work while exiting and thinking that a save opportunity would be presented. Second time I pushed to the finish line without exiting the HE model and was able to see the model. The nozzles did not look anything like what I had tried to model, at least the one on the top chanel. The good thing is that I was able to Edit the nozzle once I completed the HE model.
Any suggestions for saving the work while in the HE model in case you need to quit in midstream? Any comments about the nozzle input. I viewed the Tutorial for HE's but some of it did not correspond to the version we are currently using.
