Expanding a straight cylinder in a curved tube
i am trying to expand and deflate a cylinder (modelled as a shell) within a deformable curved tube. I am expanding and deflating the cylinder using displacement boundary conditions and a cylindrical csys. The analysis works fine except for the balloon which returns to its initial position when deflated whereas I want it to deflate to the centre of the deformed tube. Any ideas on this problem?
RE: Expanding a straight cylinder in a curved tube
I can't understand how you expand the cylinder by displacements as surely you're simply applying those displacements to the curved tube on contact? Some pictures of the model might help.
ex-corus (semi-detached)
A description of your end goal would also be useful is this for a sent?
As a guess if you turn on stabilization and expand the balloon with a pressure load then you might get your desired results.  I am guessing the stabilization is needed to remove rigid body motions because the balloon will be smaller than the bent tube.
I hope this helps.
Rob Stupplebeen
