IDEAS Drafting - Hexagonal Circles
I am creating a drawing that includes circles (holes etc). However, the circles are comming out on the screen as hexagons almost like the resolution isnt high enough or something. They are also printed like this as well.
See link for screen shot.
http:/ /files.eng ineering.c om/getfile .aspx?fold er=8f6aecc 0-e019-485 d-9bd5-8da 09ebc90f6& amp;file=h exagonal_c ircles.tif
Can anyone suggest a solution to this?
I am using IDEAS 5 m3, on sun/solaris system. I am using a Sun Ultra 45 workstation.
Many thanks in advance for any advice.
Lee
http:/
Lee
RE: IDEAS Drafting - Hexagonal Circles
Select your view and click on view properties or just type in vs
Then select the second icon from the left
See pic
Then YOu will see a Bar that says either fine,mendium or coarse hidden you need to hold this down and go to precise. Then update your view
This is in your user directroy
hidden_line_processing_option=4
Your is probably set to 1-3
it needs to set to 4
Lee
