Coordonate system
Coordonate system
Coordonate system
Hello everybody !
Hou can i add a new coordonate system in SE to be loaded by default? I think i have to add a file in C:\program_files \se.... but I am not sure how.
I am using SE20 but I suppose in all is the same .
Many thanks in advance !!!
Good Day
RE: Coordonate system
just open the template file(s) in Solid Edge (C:/Program Files/Solid Edge V20/Templates). Start the command called 'coordinate system' and choose the 'key-in' option then just accept the different steps without changed and the coordinate system should be created at 0,0,0. Save the template file.
Fred
