Wall saw cutting rates
We are using a Hilti wall saw for a demolition project. There is about 3,000m of reinforced concrete wall to cut, we have a wall saw with diamond tipped cutting discs. THe wall thickness is 300mm.
Does anyone have experience of a similar job and knows the cutting speed and the number of metres each blade will cut before needing to be replaced?
