Transformer Help
Transformer Help
Transformer Help
I am working on a building that will be supplied with a 480V feed.  For the building I need 240V (3Phase) as well as 208V and 120V.  Are there and Transformers that can supply all of these voltages or will I require two seperate transformers?
Thanks!
RE: Transformer Help
That would require two different transformers.  But three-phase 240V is worth trying to get rid of.  If you have 208V three-phase and 480 V three-phase, there should not be any need for 240 V three-phase, unless there is some very specific need.
This assumes you are in the US.
David Castor
www.cvoes.com
If you only need a small amount of 240V 3 phase, the most economical solution may be a 2:1 open delta autotransformer fed from the 480V system.
I concur with dpc on trying to avoid 240V three phase.
Bill
"Why not the best?"
Jimmy Carter
Thanks guys.  I thought I would need two transformers.  I actually have to power up a 480v and 240v 3 phase motors.  208v for lights and 120v for standard receptacles.  I just found out that I would need a 240v a couple days ago.
Most 230V (for use on 240V) motors may be reconnected for 460V for use on 480V systems).
Or;
Can you change out the 230V motors for 200V motors?
Bill
"Why not the best?"
Jimmy Carter
Agreed with the above, anything you can do to eliminate the 240V system will be a good thing.
